Zero sequence current phase failure protection circuit
Source: InternetPublisher:zht24 Keywords: Protection circuit zero sequence current phase failure protection Updated: 2021/01/14
It uses zero sequence current to achieve phase failure protection . When the three-phase current is balanced,
the TA secondary of the zero-sequence current transformer has no output; when the power supply phase is disconnected, the TA secondary has an output, causing KA to release, KM to release, and the motor
to stop rotating.
In the figure, oz is the winding added to the contactor KM coil to obtain a voltage of 12~15V . After the voltage
is rectified by the rectifier bridge, C, and filtered by the capacitors C3 and C4, it is supplied to the operating voltage of the triode circuit .
- Analysis of the working principle of the sound and light controlled delay switch circuit
- How to choose the right level of integration to meet motor design requirements?
- Use your smartphone to turn on/off the power in your home
- How to build a simple tachometer using an infrared reflectance sensor
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- How to make a wheeled self-balancing robot using ultrasonic sensors
- How can we make the robot move precisely on a predefined path?
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Design and analysis of wire control circuit
- Homemade short circuit alarm device
- Motor overcurrent protection circuit
- Leakage current protection circuit
- Overload protection circuit for high-voltage motors
- High voltage automatic protection circuit
- Thyristor silicon stack protection circuitb
- Thyristor resistance-capacitance protection circuit b
- Structure and working principle diagram of various protection circuitsg
- Power overload detection box protection circuit
- Alarm and protection circuit using operational amplifier
- Diesel generator speed protection circuit
