Phase failure protection circuit 2 for detecting line current
Source: InternetPublisher:JFET Keywords: Protection circuit phase failure protection BSP Updated: 2021/11/26
The current signals detected by the three current transformers are rectified and filtered and output into
three DC voltages, which are added
between the base and emitter of the transistors VTi, VT2 and VTa respectively. After the signal is amplified by three
transistors, it is connected to
an OR gate circuit composed of diodes VD4, VDs, and VD6. The OR gate circuit controls
the conduction or cutoff of the transistor VT4, thereby controlling
the pull-in or release of the intermediate relay KA. When the power supply loses
phase, KA pulls in, causing the contactor KM to release, and
the motor stops. The disadvantage of
this protection circuit is that when the stator winding is connected in a △ shape, the current
in the phase-opening line inside the motor winding does not drop to zero, and the protection device will not
operate at this time.
- How to remotely control devices using ESP8266 and LPC2148
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- What are the challenges in designing a permanent magnet linear generator?
- Manual automatic air compressor control circuit
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Design and analysis of voice control circuit
- Do-it-yourself trial production of phase failure protection device
- Design and production of no-load automatic power-off device for household power supply
- Ultrasonic blind pathfinder circuit
- Inpatient pager circuit
- soil content measurement circuit
- ring amplitude modulation circuit
- Diode balanced amplitude modulation circuit
- Schiller oscillator circuit
- Crabo oscillator circuit
- Second-order active band-stop filter circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Power phase sequence display circuit
