High frequency emergency fluorescent lamp
Source: InternetPublisher:aytwartoofyoroo Keywords: High frequency emergency light circuit Updated: 2024/08/12
As shown in the figure, this is the circuit of the high-frequency lighting generator. It uses 8V~14V batteries as energy, and then lights up 6W~12W fluorescent lamps after oscillation and voltage boost. The crystal triode VT can use low-frequency high-power triodes such as 3DD12A, D3D4D, 3DD5C, 3DDl5A, etc. When assembling, it should be installed with a 70mm×40mm×2mm aluminum plate heat sink; the potentiometer RP is best to use a small wire-wound type; the high-frequency pulse transformer T can be made with a ferrite magnetic tank with a diameter of 22mm; the coil L1 is wound flatly on the skeleton with a high-strength enameled wire with a diameter of 1mm for 9 turns; the feedback coil L2 is wound flatly on the outside of L1 with a high-strength enameled wire with a diameter of 0.3mm for 8 turns; the coil L3 is wound flatly with a high-strength enameled wire with a diameter of 0.2mm for 900 turns.
- What is a self-locking circuit?
- How to choose the right level of integration to meet motor design requirements?
- Model rocket launch controller circuit
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Methods for Eliminating Noise of Brushed DC Motors
- Design and production of wireless multi-location control switch circuit
- Design and manufacture of three-phase motor protection circuit
- PIC microcontroller controlled remote anti-theft alarm circuit
- Guanghua brand anti-theft doorbell electronic lock circuit
- Rural fish farming control circuit
- Differential amplifier emitter negative feedback gain control circuit
- Water and electricity saving infrared control circuit
- Schematic diagram of motor PLC control circuit
- PLC transmission line automatic reclosing control circuit
- 24h automatic switching capacitor control circuit
- Electric heater temperature detection control circuit
- Control circuit of Gao Shida 25860T microwave oven turntable assembly
- Micro DC motor steady speed control circuit a
- Voltage servo motor and control circuit
