Portable emergency light with automatic stop function
Source: InternetPublisher:Lemontree Keywords: Lighting Control Updated: 2024/06/17
After the power is turned on, press SW1 once, and the charging indicator LED lights up. At this time, due to the low battery, the voltage of the "e" pole of Q1 is lower than the voltage of the "b" pole, so Q1 is cut off, Q2 is also cut off, Q3 is turned on to attract the relay, J1-1 is closed and self-locked, and charging begins; when the battery voltage is charged to 7.5V, Q1 turns from cutoff to on, Q2 is also turned on, Q3 loses the base voltage and cuts off, J1 loses power and releases, the power is disconnected, charging stops, and the charging indicator LED goes out. In the figure, D1 is an isolation diode, which can prevent the battery from discharging in reverse, and adjusting RW1 can make the circuit charge batteries of different voltages.
- Analysis of the flow direction of transistor current
- Which one is better, NPN or PNP transistor?
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- What is the difference between CPLD and FPGA?
- Working principle and truth table of JK flip-flop
- Share an interesting LED decoration project
- Causes of PCB deformation How to prevent circuit board bending and warping
- Touch circuit design and analysis
- A practical automatic electronic welcome circuit
- High-rise residential walkway lighting control circuit
- Apply LOGO! Lighting control circuit to realize multi-function switchb
- Apply LOGO! Lighting control circuit to realize multi-function switch a
- Conventional stair lighting control circuit
- Conventional lighting control circuit
- Simple lighting control circuit
- Fading on and off lighting control circuit
- Automobile cab delayed lighting control circuit
- Contactless lighting control circuit
