DC motor reverse braking circuit a
Source: InternetPublisher:Lemontree Keywords: DC motor braking circuit BSP relay Updated: 2021/03/29
The circuit is shown in Figure 3-200 (a). When reverse braking occurs, the contacts of the forward contactor KMi are disconnected, the
contacts of the reverse braking contactor KM3 are disconnected, and the contacts of the reverse contactor KM2 are closed. The setting circuit of
reverse-connected relay KA is shown in Figure 3-200 (h). Through the reverse connection relay KA, when the reverse connection braking starts
, the reverse connection braking resistor Rf is connected to the armature circuit; and when the motor speed is close to zero after braking, the reverse connection braking resistor
Rf is short-circuited. The connection point A of the relay KA coil is determined by the resistance value of R:. Point A should be
at half of the total resistance (Rq + Rf). The pull-in voltage of relay KA is generally set at (0. 4 ~ 0. 45) Ue.
- How to choose the right level of integration to meet motor design requirements?
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- DC motor drive circuit composed of L293D
- Methods for Eliminating Noise of Brushed DC Motors
- Design and analysis of wire control circuit
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Design and analysis of a four-bit remote control component capable of remote reset
- Do-it-yourself trial production of phase failure protection device
- Password type motorcycle anti-theft device
- Fish farming thermostatic control circuit
- Particle clogging alarm circuit of wheat seeder
- Greenhouse temperature control circuit
- Biogas concentration detection line
- AC voltmeter
- Simple AGC circuit in transistor radio
- Audio function generator composed of ICL8038
- Differential Amplifier Circuit
- Color display circuit
- Three primary color display circuit
