LED lamp with self-contained lead-acid battery
Source: InternetPublisher:aytwartoofyoroo Keywords: LED Circuit Updated: 2024/08/26
LED lamp with lead-acid battery that can be charged.
The circuit working principle diagram drawn according to the actual object is shown in Figure 5. The 220V AC mains is charged to the lead-acid battery after capacitor voltage reduction and diode rectification, and the red LED is used as a charging indicator. When the button switch K is closed after charging, 3 colored flashing LEDs will be connected first, emitting a dreamy and unpredictable colorful light, adding some fun to life at night. Press the switch K again to turn off the colored flashing LEDs, and then press it again to connect 24 high-brightness LEDs in parallel. Due to the large number, the lighting effect is very good.
When the lead-acid battery voltage is 4V, the measured working current of the colored lamp is about 60mA, and the current of the high-brightness LED is as high as more than 600mA. Such a large current not only makes the lighting time not too long after each full charge, but also damages the internal structure of the battery and shortens the service life. Therefore, a small resistance current limiting resistor must be connected in series with the high-brightness LED. After multiple tests, the working current is finally reduced to 320mA when 1.2Ω is selected, and the brightness change is not obvious. Because the lamp has not been changed much, the circuit principle diagram after the modification is omitted.
Through the above analysis, it is found that most of the various LED lamp circuits sold on the market are too simple. Although the price is very cheap, it will objectively cause energy waste. Only through reasonable improvements can we retain its economical and portable advantages and effectively improve its safety and reliability.
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- How does a series arrangement of Zener diodes affect the electrical behavior?
- This article will tell you the hard requirements of operational amplifiers
- The Importance and Ideal Model of Impedance Matching
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- How to calculate the value of capacitors in parallel?
- Simple Wired Spy Bug Circuit Built Based on IC741
- Diode-based clipping circuit
- Build a musical fountain using Arduino and sound sensor
- What is the difference between high-side and low-side resistive current sensing
- simple photometer
- Photoelectric conversion and voltage-to-current conversion circuit diagram
- Capacitor step-down LED drive circuit diagram using varistor
- Capacitor step-down LED drive circuit diagram using thyristor
- Energy-saving household small neon light circuit production
- Typical circuit diagram of LED indicator integrated circuit
- Novel solar LED light controller circuit diagram
- LED lighting circuit diagram in refrigerator
- MIC2298 driving LED circuit diagram
- MAX1913 driving white LED circuit diagram
