newrudeman
Wiring Guidelines for Parametric Measurement Units (PMU)
As with all precision electronic circuits, the best possible performance can be obtained by selecting appropriate peripheral components and circuit layout. This application note describes the circuit design, compensation, layout, and thermal handling requirements for the MAX9949/MAX9950 PMU components.
Device Description
The MAX9949 / MAX9950 are dual PMU devices suitable for use in automatic test equipment (ATE) and other similar instrumentation. It has the characteristics of small size, wide loading, measurement range, and high accuracy. It is very suitable for measurement equipment that requires one PMU per pin or per point. The MAX9949/MAX9950 have built-in buffer drivers that can expand the operating range of the PMU device voltage and current according to user needs.
Typical circuit
Click to enlarge
Documentation
Search Datasheet?
Forum More
Update:2025-08-05 07:34:16
