ghaytweyhtoo
5 W + 5 WD Class Audio Amplifier Demonstration Board Based on TDA7491LP
STEVAL-CCA029V1
The STEVAL-CCA029V1 demonstration board is designed for the evaluation of the TDA7491LP dual BTL class-D audio amplifier.
Due to its high efficiency, the device, assembled in the PSSO36 (slug-down) package, is capable of dissipating heat without any heatsink. Jumpers on the board allow the configuration of the amplifier in order to verify all the features as single-ended or differential inputs, fixed gain settings. Microswitches are also provided to enable the standby and mute functions.
Main features
  • 5 W + 5 W continuous output power at THD = 10%, RL = 8 Ω, VCC = 9 V
  • 5 W + 5 W continuous output power at THD = 10%, RL = 4 Ω, VCC = 6.5 V
  • Power supply voltage range: 5 V to 14 V
  • Number of channels: 2 BTL (bridge tied load) stereo
  • Load impedance: 4 Ω to 8 Ω
  • Gain settings: 20 dB, 26 dB, 30 dB, 32 dB
  • Undervoltage protection (UVP): 4 V
  • External synchronization
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 09:54:57
  • Dear SOSO
  • Several key points of TI's official two-phase LLC interleaving parallel procedure (to be continued)
  • uCOS-ii transplantation
  • 18B20 shows FFF
  • The third phase of EEWORLD official bidding activity - book bidding
  • linux 0.1~ various versions mirror
