3228
Industrial digital output expansion board based on IPS160HF, suitable for STM32 Nucleo
X-NUCLEUS-OUT08A1
The X-NUCLEO-OUT08A1 industrial digital output expansion board for STM32 Nucleo provides a powerful and flexible evaluation and development environment for 2 A (typical) digital output modules, with safe driving and intelligent diagnostics of the IPS160HF single high-side switch.
The X-NUCLEO-OUT08A1 interfaces with the microcontroller on the STM32 Nucleo via a 3 kV optocoupler driven by GPIO pins and Arduino™ UNO R3 (default configuration) and ST morpho (optional, not installed) connectors.
The expansion board can be connected to a NUCLEO-F401RE or NUCLEO-G431RB development board or stacked with another X-NUCLEO-OUT08A1 or X-NUCLEO-OUT10A1.
Two X-NUCLEO-OUT08A1 expansion boards can be used to evaluate a dual-channel digital output module with 2 A (typ.) capability per channel or a 2 A (typ.) single-channel safe digital output module. In the second scenario, the first shield output is connected to the power supply of the second shield output. Dedicated onboard hardware can be enabled or disabled to activate rapid discharge of highly capacitive loads, output voltage sensing and additional surge pulse output line protection.
Main features
  • Based on IPS160HF single-channel high-side switch, its characteristics are as follows:
    • Can operate at 60 V/2.4 A
    • Low power dissipation (R ON(MAX) = 120 mΩ)
    • Rapid decay of inductive loads
    • Open load detection and diagnostics
    • Overload and overtemperature protection via thermal shutdown and fusing
    • PowerSSO-12L package
  • Application board operating range: 12 - 33 V/0 - 2.4 A
  • Extended operating voltage range (J1 open) up to 60 V
  • Status and diagnostic LEDs
  • 3 kV electrical isolation
  • Power rail reverse polarity protection
  • Compatible with secure digital output architecture
  • EMC complies with IEC61000-4-2, IEC61000-4-3, IEC61000-4-5
  • Has broad application development potential in the STM32 Nucleo development environment
  • Comes with Arduino™ UNO R3 connector
  • CE certification
  • Compliant with RoHS and Chinese version of RoHS standards
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 23:23:00
