toothache
L9945 Engine Management System Evaluation Board
EVAL-L9945
The EVAL- L9945 is an evaluation board designed to evaluate L9945, a smart power device designed by STMicroelectronics in advanced BCD technology.
L9945 is a flexible high-side/ low-side configurable pre-driver able to drive both NMOS and PMOS. It is possible to configure the device as independent 8 high-side and low-side pre-driver or as 2 H-Bridge pre-driver or 2 pick and hold pre-driver by using SPI configuration and jumper on the board.
All channels are protected against short circuit, over current and over-temperature conditions.
The board can be connected to the SPC563M-DISP, the Discovery+ board developed for the SPC563M64L.
Main features
  • Voltage min/max: 3.8 V to 36 V.
  • 8-channel configurable MOSFET pre-driver:
    • High-side (N-channel and P-channel MOS)
    • Low-side (N-channel MOS)
    • H-bridge (up to 2 H-bridge)
    • Peak & Hold (2 loads)
  • Device registers setting and the full diagnostic are available through SPI.
  • Access to all relevant pins by test points.
  • Input signal connector compatible with the SPC563M-DISP (SPC563M64L Discovery+ evaluation board).
  • Possibility to connect a generic microcontroller board by using a simple adapter.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 19:05:53
