ghaytweyhtoo
VL53L5CX breakout board
VL53L5CX-SATEL
The VL53L5CX-SATEL breakout boards can be used for easy integration into customer devices.
[VL53L5CX-SATEL_web.jpg]
The PCB section supporting the VL53L5CX module is perforated so that developers can break off the mini PCB for use in a 3.3 V supply application using flying wires. This makes it easier to integrate the VL53L5CX-SATEL breakout boards into development and evaluation devices due to their small size.
所有功能
VL53L5CX Time-of-Flight 8x8 multizone ranging sensor with wide field of view
Regulator: 5 to 3.3 V range input voltage (output voltage: 3.3 V)
True distance measurement independent of target size and reflectance
Divisible board enabling use as mini PCB breakout board, easy to integrate in customer device
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 15:02:53
