Lemontree
Teseo V Evaluation Board
EVB-T5
The EVB-T5 board is a complete standalone evaluation platform for Teseo-V STA8100GA GNSS Multi Band and Multi Constellation Receiver with STA5635A RF Front-End IC solution.
The EVB-T5 is designed for best STA8100GA and STA5635A best performance. Boot and Reset buttons allow an easy programming procedure.
The 4-pins connector allows access to the ODO/CAN signals to simplify car-connection.
Teseo-V embeds the high performance ARM Cortex-M7 microprocessor with RF front-end able to support different bands (L1, L2 and L5), UART communication interfaces.
The STA5635A is a fully integrated RF front-end able to support different bands (L2 and L5) with a programmable IF Bandwidth (7 or 13 MHz).
Performance and configuration can be analysed using the ST Teseo Suite PC Tool available on www.st.com.
Main features
  • ST Teseo-V STA8100GA with RF Front-End STA5635A GNSS platform
  • Multiconstellation and MultiBand GNSS: GPS, Galileo Glonass, BeiDou, QZSS supported
  • USB Power Supply
  • Button:
    • ON/OFF button
    • Reset button
    • Boot button
  • NMEA over
    • UART by USB
  • PPS output
  • Leds:
    • PPS
    • Power
    • Antenna
  • ODO/CAN connector
  • ST ASM330LHH MEMS
Search Datasheet?
Forum More
Update:2025-08-08 03:30:17
