supremeOne
Evaluation platform based on BlueNRG-355MC system-on-chip
STEVAL-IDB011V1
The STEVAL-IDB011V1 evaluation platform is designed to help you develop and test Bluetooth® low energy applications using the low power BlueNRG-LP system-on-chip in combination with inertial and environmental MEMS sensors and digital MEMS microphone, and various interface buttons and LEDs.
The BlueNRG-LP features a 64 MHz, 32-bit ARM® Cortex®-M0+ core, 256 KB programmable Flash, 64 KB SRAM, MPU, and an extensive peripheral set (6x PWM, 2x I²C, 2x SPI/I2S, SPI, USART, UART, PDM, 12-bit ADC SAR). It is compliant with the Bluetooth® LE specification, supporting master, slave, and simultaneous master-and-slave roles, data length extension, 2 Mbps, long range and extended advertising and scanning features.
Main features
  • Bluetooth® low energy evaluation board based on the BlueNRG-LP Bluetooth low energy system-on-chip (QFN48 package)
  • Associated BlueNRG-LP development kit SW package (STSW-BNRGLP-DK) including firmware and documentation
  • Up to +8 dBm programmable output power (at antenna connector)
  • Excellent receiver sensitivity (-96 dBm @1 Mbps, -103 dBm @125 bps long range)
  • Very low power consumption: 3.4 mA RX @ sensitivity level, and 4.3 mA TX @ +0 dBm
  • Supports master, slave, and simultaneous master-and-slave roles
  • Bluetooth low energy data length extension, 2 Mbps, long range and extended advertising and scanning
  • SMA connector for antenna or measuring equipment
  • Arduino R3 connectors
  • 3 user LEDs and 2 user buttons
  • MEMS digital accelerometer/gyroscope
  • MEMS digital pressure/temperature sensor
  • MEMS digital microphone
  • Embedded CMSIS-DAP debugger and drag&drop programming support
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-23 15:14:38
  • Texas Instruments' first integrated ultrasonic T/R switch
  • S3C2440 65x45mm core board circuit diagram
  • Problems encountered in Keil
  • nor flash erase
  • TI C6000 Series Pipeline Concept
  • Regarding some issues with ERC checking in DXP, thank you for your help! ! Urgent~~
