toothache
LNB power supply demonstration board based on LNBH23
STEVAL-CBL005V1
The STEVAL-CBL005V1 LNB power supply demonstration board implements a DC-DC converter based on the LNBH23 device. The LNBH23 is an LNB supply and control IC with step-up and an I2C interface. It is used to power an LNB on a dish antenna for reception of satellite TV signals.
The LNBH23 is an integrated solution for supplying/interfacing satellite LNB modules in accordance with international standards.
This solution is simple, inexpensive, shows very good performance and has a low external component count.
The LNBH23 demonstration board includes an I2C™ bus interface and an internal 22 kHz tone generator that is factory-trimmed to comply with widely accepted standards, and can be controlled through the DSQIN pin (TTL compatible). This allows immediate DiSEqC™ data encoding.
Due to the fully integrated step-up DC-DC converter, it works with a single input voltage supply source ranging from 8 V to 15 V.
Main features
  • Implements the LNBH23 in a QFN32 package
  • Integrated DC-DC converter
  • I2C™ bus interface for the IC control and diagnostics
  • Single input supply voltage: from 8 V to 15 V
  • User-friendly graphical user interface ("LNBxxx control suite") software included in the kit
  • Integrated 22 kHz tone generator, factorytrimmed in accordance with widely accepted standards
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 06:38:19
  • Several methods to detect the quality of transformers in power supplies, please add
  • About key functions
  • Several key functions about the serial port
  • About FPGA power-on reset
  • About SD card reading and writing ~
  • TMS320C5402 interrupt system based on c2000
