ghaytweyhtoo
Simulated wall dimmer for CFL/LED lamps based on TS820 (EU 220 V version)
STEVAL-ILD003V1
The STEVAL-ILD003V1 demonstration board is designed to propose a low-cost analog dimmer topology using a sensitive SCR TS820-600FP. The dimmer can drive typical low-consumption lamps, particularly CFL and LED dimmable lamps.
Through-hole technology is used for the most important components such as LC filter, gate resistor, turn-on delay capacitor, etc., in order to allow board modification, if needed.
The STEVAL-ILD003V1 eliminates flickering thanks to its continuous current applied through the sensitive SCR gate. This dimmer could easily replace a standard low-cost analog Triac light dimmer using a Diac-controlled circuit.
Main features
  • Operation for 2-wire wall dimmer
  • Leading-edge control (compatible with all lamps commonly found on the market)
  • Operation on 230 V line rms voltage (198 to 264 V) and 50 Hz or 60 Hz line frequency
  • Dimmable power range with halogen, CFL and LED lamps (without heatsinks mounted on SCRs1):
    • 3 to 350 W for 230 V rms line
  • Maximum operating ambient temperature: 60 °C
  • Power efficiency @ 350 W / 230 V > 99%
  • Standby losses @ 230 V
  • RoHS compliant
  • Compliance with EMC standards
    • IEC 61000-4-4: criteria A for more than 2 kV
    • Compliant with EN55015 with 350 W / 230 V halogen lamp
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 00:34:40
