ohahaha
Using L6563 and L6566A, 19V-75W SMPS that meets the latest Energy Star standards
EVL6566A-75WES4
This board implements a 75 W SMPS reference design, tailored to the specifications of a typical hi-end portable computer power supply (adapter). The peculiarities of this design are the very high efficiency at light load and the excellent global efficiency for a two-stage architecture. The high efficiency at high load is achieved without using synchronized rectification at secondary side and therefore offers a very cost effective solution.
The circuit is made up of two stages: a front-end PFC using the L6563 and a flyback converter based on the L6566A. The CV/CC controller TSM1014 allows the correct current limitation on the secondary side. The flyback stage works as master and it is dedicated to controlling the circuit operation, including the standby and protections. Additionally, it switches the PFC stage on and off by means of a dedicated pin (VCC_PFC), therefore helping to achieve an excellent efficiency even at light load, with low complexity.
Efficiency during active load and light load operation are compliant with Energy Star® Eligibility Criteria for both external (EPA rev. 2.0 EPS) and computer integrated (EPA rev. 4.0 COMPUTERS) power supplies. In addition, this design is also compliant with the latest computer requirements.
Main features
  • Universal input mains range: 90 - 264 Vac- Frequency 45 - 65 Hz
  • Output voltage: 19 V @ 4 A continuous operation
  • Mains harmonics: Acc. to EN61000-3-2 Class-D or JEIDA-MITI Class-D
  • Standby mains consumption: ac, ac
  • Active load average efficiency: better than 87% without synchronous rectification
  • EMI: According to EN55022-Class-B
  • Safety: According to EN60950
  • Dimensions: 78x170 mm, 25 mm component maximum height
  • PCB: Single side, 70 μm, CEM-1, Mixed PTH/SMT
Search Datasheet?
Forum More
Update:2025-07-17 17:28:09
