3228
38 V, 0.5 A synchronous step-down switching regulator evaluation board based on A6985F5V
STEVAL-ISA186V1
The STEVAL-ISA186V1 is a product evaluation board based on the A6985F5V ST synchronous step-down switching regulator, which can deliver up to 0.5 A and, with its 100% duty cycle ability to withstand cold crank events and wide input operating voltage range, renders the A6985F5V the ideal choice for battery-powered automotive systems. Synchronous rectification helps achieve higher efficiency at full load as well as application compactness, while high-frequency switching (programmable up to 2 MHz) helps to reduce the cost and size of power passive components while remaining outside the AM band. The device can operate in low consumption mode (LCM) with a quiescent current of 45 μA, hence ensuring the high efficiency under light load condition required in typical car body applications that are active when the car is parked. A low noise mode (LNM) can be selected to meet the requirements of infotainment applications with forced PWM mode under all load conditions. The default board configuration is LCM active, 2 MHz switching frequency, high ISKIP current and the switchover feature enabled, but all of these settings can be easily changed so the user can evaluate different application scenarios.
Main features
  • AECQ100 qualification
  • 0.5 A DC output current
  • 4 V to 38 V operating input voltage
  • Low consumption mode or low noise mode
  • Programmable I SKIP current
  • 45 μA IQ at light load (LCM VIN = 12 V)
  • 8 μA IQ-SHTDWN
  • Adjustable fSW (250 kHz - 2 MHz)
  • Fixed output voltage VOUT = 5 V
  • Embedded output voltage supervisor
  • Synchronization
  • Adjustable soft-start time
  • Internal current limiting
  • Overvoltage protection
  • Output voltage sequencing
  • Peak current mode architecture
  • RDS(on)HS = 360 mΩ; RDS(on)LS = 150 mΩ
  • Thermal shutdown
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 15:03:30
  • Why can stm32 +tm1638 only display but not read keys?
  • ucGUI defragmentation question - CreateHole
  • Spoken English, speak bravely!
  • Safety of test systems in DC production testing of OLED displays
  • Problems with microcontroller driving buzzer
  • Ask about AD conversion
