3228
Dual Output Isolated SSR Flyback Converter Using VIPER267KDTR for Smart Meters and PLC Systems
STEVAL-VP26K02F
The STEVAL-VP26K02F evaluation board implements a double output isolated SSR flyback specifically designed to supply smart meter and PLC systems.
The evaluation board has been developed using the VIPER267KDTR offline high-voltage converter which features a 1050 V avalanche-rugged power section, PWM operation at 60 kHz with frequency jittering for lower EMI, current limiting with 700 mA fixed set point, on-board soft-start, safe auto-restart after fault and low standby power.
The power supply provides 12 V at 700 mArms (1 A peak) to the power line modem (PLM) and the analog circuitry, and 6 V at 200 mA to supply digital circuitry and other low voltage parts.
The power supply is designed to operate across a three-phase input mains from 50 to 290 VAC but can also be connected to a single phase mains from 85 to 500 VAC.
Main features
  • Double output voltage: 12 V at 0.7 Arms (1 A peak) and 6 V at 200 mA
  • Secondary side regulation (SSR)
  • Extended AC mains input voltage range: 85 to 500 VAC
  • EMC with EN55022, EN61000, EN61000-4-4, EN61000-4-5, EN61000-4-6
  • WEEE compliant
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 00:39:22
  • STM32F207 and 103 are compared
  • Does anyone use makefile to batch process arm programs?
  • Can the built-in FLASH of STM32 be used as a USB flash drive?
  • 6410 interrupt problem!
  • What is the difference between IC324D and 324N in the intercom doorbell?
  • How to Play Linux
