Lemontree
65W USB Type-C PD AC/DC adapter reference design with 30W/in3 power density and 94% efficiency
TIDA-01622
This fully tested, USB power delivery reference design is a high efficiency, high power density, AC/DC adapter solution with a wide input voltage range (85 - 265VAC) for laptop adapters and smartphone charger applications. It adopts active-clamp-flyback topology controlled by TI’s newest ACF controller UCC28780 as the mainly power supply stage. This design uses TPS25740B, TI’s PD source controller, to achieve a full PD 2.0 function. The design achieves a peak efficiency of 94% at a very high switching frequency. The design’s power density is increased to 30 W/in3, which is much higher than traditional solutions.
characteristic
  • ● High efficiency (94% peak value)
  • ● High power density (30W/in³)
  • ● Low no load power consumption (60mW)
  • ● Low light load input power (0.5W), @20Vout/0.25W output
  • ● Fully compatible with USB PD 2.0 standard, with 5V/3A, 9V/3A, 15V/3A, 20V/3.25A output
  • ● Active-clamp flyback + SR topology
  • ● Small size (62mm*28.6mm*18.4mm)
Backlog Impt notice changes Backlog Impt notice changes end
参考设计图片
Blockdiagram
Search Datasheet?
Forum More
Update:2025-07-01 19:04:45
  • New Year's greetings to eeworld friends
  • Problems with structures in C language
  • STM32 drives LCD 12864, there is a program, help
  • Help me choose a power supply, thanks.
  • 【LPC54100】Board received, the second batch, really complained
  • How to distinguish whether it is USB or SD card insertion and removal
