MartinFowler
Isolated shunt current measurement reference design with independent digital filter
TIDA-01639
This reference design utilizes an isolated modulator and independent digital filter to implement a Class 0.5 three-phase power measurement system with an isolated shunt sensor, eliminating the need for an integrated synchronization filter and allowing an optional host microcontroller (MCU). ) will be broader in scope. In this design, the current sensed by the isolated modulator and the phase voltage sensed by the host microcontroller are synchronized; more advanced metering algorithms are supported using the Simplelink™ ARM Cortex M4 host MCU. This design protects against magnetic tampering attacks by using current sensors and a power supply that does not use any transformers or other magnetic components. This subsystem design has been tested and includes hardware.
characteristic
  • ● Category 0.5 three-phase metering with galvanically isolated (up to 600VRMS, peak isolation voltage 4kVRMS) shunt sensors
  • ● Electrically isolated shunt sensor and capacitive voltage drop power supply provide immunity to magnetic field interference
  • ● Standalone digital filter enables use of host microcontroller without digital filter, thus increasing design portability
  • ● Synchronous voltage and current sampling across all phases and the ARM® Cortex® M4 host MCU enable the addition of advanced metering algorithms
  • ● Active and reactive energy, root mean square (RMS) current and voltage, power factor and line frequency calculations
Backlog Impt notice changes Backlog Impt notice changes end
参考设计图片
Blockdiagram
Search Datasheet?
Forum More
Update:2025-08-06 19:01:16
