fish001
38 V, 3 A synchronous step-down switching regulator evaluation board based on L6981NDR
STEVAL-L6981NDR:38 V, 3 A synchronous step-down switching regulator evaluation board based on the L6981NDR
The STEVAL-L6981NDR is based on the L6981NDR synchronous monolithic step-down regulator delivering up to 1.5 A DC.
[STEVAL-L6981NDR IMAGE]
Its wide input voltage range makes the solution suitable for a broad range of applications.
The device implements peak current mode architecture in a SO 8L package with internal compensation to minimize design complexity and size.
The L6981NDR is available in low consumption mode (LCM) and low noise mode (LNM) versions.
LCM maximizes efficiency at light-load with controlled output voltage ripple, making the device extremely suitable for battery-powered applications.
LNM makes the switching frequency constant and minimizes the output voltage ripple overload current range, meeting the specification for noise sensitive applications.
The EN pin manages the enable/disable function. The typical shutdown current is 2 μA when disabled. When the EN pin is pulled up, the device is enabled and the internal 1.3 ms soft-start takes place.
Pulse-by-pulse current sensing on both power elements implements effective constant current protection while thermal shutdown prevents thermal run-away.
All features
3.5 V to 38 V operating input voltage
Output voltage from 0.85 V to VIN
3.3 V and 5 V fixed output voltage versions
1.5 A DC output current
17 μA operating quiescent current (fixed Vout part numbers)
Internal compensation network
Two different versions: LCM for high efficiency at light loads and LNM for noise sensitive applications
2 μA shutdown current
Internal soft-start
Enable function
Overvoltage protection
Output voltage sequencing
Thermal protection
SO 8L package
Synchronization with external clock for LNM devices
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 08:45:01
  • Low-pass filter waveform distortion problem
  • Questions about PCB antenna
  • Some of the boards returned by Samsung 6410 can be turned on and some cannot!
  • EEWORLD University Hall----Most people can't do a backflip, but Boston Dynamics robot Atlas can do it!
  • Four doubts
  • Long-distance identification card/electronic tag/RFID/active card
