newrudeman
Freescale smart car CCD program
soft start
Double the sampling rate
50Hz
Steering gear correction is more convenient
Serial port modification PID
Improve anti-interference ability
speed adaptive
After the speed detection circuit is improved
Wireless setting parameters (OK)
//Use the front row to follow the line (changed to the first 3 rows, 2007.5.7)
PIDs are expanded 10 times (changed to adaptive PID 2007.5.2)
Braking intensifies (2007.5.7)
m_cSampNum = -24;(changed to -25)
Enhanced anti-interference ability (can come back after running off the runway 2007.5.7)
Add filtering algorithm (unsuccessful 2007.5.20)
External AD(2007.5.23)
//50X40
//Use the maximum and minimum center methods to control steering
Control steering using inertial filtering method
The external AD data port is changed to AD0
High resolution 72X40 2007.5.25
Lower the threshold 20->15
speed smoothing
Reduce the number of rows
Delete lines at intervals to reduce trapezoidal distortion 2007.5.30
Two laps 25.12 seconds 2007.6.1
CarCCDtest11_change3_72X40_EXAD5_7C6huang Modified from 2007-7-30
Use the PD control algorithm and use the center of the sub-left and sub-right of the effective row as the control quantity to control the direction.
Search Datasheet?
Forum More
Update:2025-07-08 22:46:48
