石榴姐
Level 1 deceleration racing car arduino control
After actual testing, the car ran very fast and easily lost control. This motherboard is suitable for controlling large motors. Now I am considering using RZ7899 to control the output in parallel or using a Loli remote control. The next finished product is expected to take a long time because I have to concentrate on learning and I encountered a bottleneck (I don’t know how to write the program controlled by 2.4hhz pwm. I would be very grateful if someone can help me). This time the car is very powerful. With the addition of a reducer, I am not afraid of the wheels falling off. It is recommended to add a 104 capacitor to the motor to eliminate high-frequency interference.
Manufacturing process display: https://www.bilibili.com/read/cv6217381 Video results display https://www.bilibili.com/video/bv1cz411B7Se https://www.bilibili.com/video/bv1A5411s7Vs IMG_20200522_171527.jpgIMG_20200522_171521.jpgIMG_20200522_101023.jpg The program is here:
//// Communication protocol start
//// ----the only thing you need to do is modifying the numbers of variables according to your demand
//****define what to send to cell phone*******************
#define NUM_TX_BOOL   0
#define NUM_TX_ByTE   0
#define NUM_TX_SHORT  2
#define NUM_TX_INT    0
#define NUM_TX_FLOAT  0
//****define what we want to get from cell phone********
#define NUM_RX_BOOL   3
#define NUM_RX_ByTE   5
#define NUM_RX_SHORT  0
#define NUM_RX_INT    0
#define NUM_RX_FLOAT  0
// size of Loop Buffer is editable depending on the data packet transmission rate and memory space
#define LOOP_BUFFER_SIZE 512
#define SIZE_RECV_PERTIME 64  // fixed
//Do not change the code below+++++++++++++++++++++++
// data structure to send to phone
struct {
bool bools        [NUM_TX_BOOL];
int8_t bytes      [NUM_TX_ByTE];
int16_t shorts    [NUM_TX_SHORT];
int32_t  integers [NUM_TX_INT];
float   floats    [NUM_TX_FLOAT];
}txPack;
// data structure to recv from phone
struct {
bool bools        [NUM_RX_BOOL];
int8_t bytes      [NUM_RX_ByTE];
int16_t shorts    [NUM_RX_SHORT];
int32_t  integers [NUM_RX_INT];
float   floats    [NUM_RX_FLOAT];
} rxPack;
byte loopBuffer[LOOP_BUFFER_SIZE];
byte rxPacketBuffer[((NUM_RX_BOOL+7)>>3)+NUM_RX_ByTE+(NUM_RX_SHORT<<1)+(NUM_RX_INT<<2)+(NUM_RX_FLOAT<<2)+3];
byte txPacketBuffer[((NUM_TX_BOOL+7)>>3)+NUM_TX_ByTE+(NUM_TX_SHORT<<1)+(NUM_TX_INT<<2)+(NUM_TX_FLOAT<<2)+3];
int16_t RXPACK_SIZE = sizeof(rxPacketBuffer);
int16_t TXPACK_SIZE = sizeof(txPacketBuffer);
int32_t INDEX_RANGE = LOOP_BUFFER_SIZE*2;
HardwareSerial *pSerial;
void initPack(HardwareSerial &serial, int32_t baudRate)
serial.begin(baudRate);
serial.setTimeout(0);
pSerial = &serial;
void getVariables(void)
unsigned char byte_pos=0,bit_pos=0;
#if (NUM_RX_BOOL>0)
for(int i=0;i<NUM_RX_BOOL;i++)
rxPack.bools[i] = (0x01<<bit_pos)&rxPacketBuffer[byte_pos];
bit_pos++;
if(bit_pos>=8)
byte_pos++;
bit_pos=0;
if(bit_pos!=0)
byte_pos++;
#endif
#if (NUM_RX_ByTE>0)
for(int i=0;i<NUM_RX_ByTE;i++)
rxPack.bytes[i] = rxPacketBuffer[byte_pos];
byte_pos++;
#endif
#if (NUM_RX_SHORT>0)
for(int i=0;i<NUM_RX_SHORT;i++)
rxPack.shorts[i] = (rxPacketBuffer[byte_pos+1]<<8)|rxPacketBuffer[byte_pos];
byte_pos+=2;
#endif
#if (NUM_RX_INT>0)
for(int i=0;i<NUM_RX_INT;i++)
rxPack.integers[i] = (rxPacketBuffer[byte_pos+3]<<24)| (rxPacketBuffer[byte_pos+2]<<16)| (rxPacketBuffer[byte_pos+1]<<8)|rxPacketBuffer[byte_pos];
byte_pos+=4;
#endif
#if (NUM_RX_FLOAT>0)
float f;
byte *p = (byte *) &f;
int pp=0;
for(int i=0;i<NUM_RX_FLOAT;i++)
p[0+pp] =  rxPacketBuffer[byte_pos];
p[1+pp] =  rxPacketBuffer[byte_pos+1];
p[2+pp] =  rxPacketBuffer[byte_pos+2];
p[3+pp] =  rxPacketBuffer[byte_pos+3];
pp+=4;
byte_pos+=4;
rxPack.floats[i] = f;
#endif
int32_t  rxIndex=0;
int32_t rdIndex=0;
int32_t err=0;
int32_t sum;
bool recvPack(void)
int start_index;
int tail_index;
int cut_size;
int rx_length;
bool isOK = 0;
int rx_pack_index;
// read bytes to loop buffer
start_index = rxIndex%LOOP_BUFFER_SIZE;
if(start_index+SIZE_RECV_PERTIME<=LOOP_BUFFER_SIZE)
rx_length+=pSerial->readBytes(loopBuffer+start_index,SIZE_RECV_PERTIME);
rxIndex+=rx_length;
}else
cut_size = LOOP_BUFFER_SIZE-start_index;
rx_length=pSerial->readBytes(loopBuffer+start_index,cut_size);
rxIndex+=rx_length;
if(rx_length==cut_size)
cut_size = SIZE_RECV_PERTIME-cut_size;
rx_length=pSerial->readBytes(loopBuffer,cut_size);
rxIndex+=rx_length;
// extract a complete packet
while(rdIndex<(rxIndex-2*RXPACK_SIZE))
rdIndex+=RXPACK_SIZE;
while(rdIndex<=rxIndex-RXPACK_SIZE)
start_index = rdIndex%LOOP_BUFFER_SIZE;
isOK = 0;
if(loopBuffer[start_index]==0xA5)
tail_index = (start_index+RXPACK_SIZE-1)%LOOP_BUFFER_SIZE;
if(loopBuffer[tail_index]==0x5A)  // Head and Tail match
rx_pack_index = 0;
// Check Summing
sum = 0;
// if data packet is divided into two segments
if(tail_index<start_index)
for(int i = start_index+1;i<LOOP_BUFFER_SIZE;i++)
rxPacketBuffer[rx_pack_index] = loopBuffer[i];
rx_pack_index++;
sum+=loopBuffer[i];
for(int i = 0;i<tail_index-1;i++)
rx_pack_index++;
sum+=loopBuffer[i];
tail_index--;
if(tail_index<0)
tail_index+=LOOP_BUFFER_SIZE;
if(loopBuffer[tail_index]==(sum&0xff))
isOK = 1;
}else // data packet is contiguous
for(int i = start_index+1;i<tail_index-1;i++)
rx_pack_index++;
sum+=loopBuffer[i];
if(loopBuffer[tail_index-1]==(sum&0xff))
isOK = 1;
if(isOK) // parse the data to rxPack
getVariables();
if(!isOK)
rdIndex++;
err++;
// limit the range of read index and recv index
if(rxIndex>INDEX_RANGE&&rdIndex>INDEX_RANGE)
rxIndex-=INDEX_RANGE;
rdIndex-=INDEX_RANGE;
return isOK;
void sendPack(void)
short byte_pos=0,bit_pos=0;
int32_t sum=0;
txPacketBuffer[byte_pos++] = 0xA5;
#if (NUM_TX_BOOL>0)
for(int i=0;i<NUM_TX_BOOL;i++)
if(txPack.bools[i])
txPacketBuffer[byte_pos] |= 0x01<<bit_pos;
else
txPacketBuffer[byte_pos] &= ~(0x01<<bit_pos);
bit_pos++;
if(bit_pos>=8)
byte_pos++;
bit_pos=0;
if(bit_pos!=0)
byte_pos++;
#endif
#if (NUM_TX_ByTE>0)
for(int i=0;i<NUM_TX_ByTE;i++)
txPacketBuffer[byte_pos++] = txPack.bytes[i];
#endif
#if (NUM_TX_SHORT>0)
for(int i=0;i<NUM_TX_SHORT;i++)
txPacketBuffer[byte_pos++] = txPack.shorts[i]&0xff;
txPacketBuffer[byte_pos++] = (txPack.shorts[i]>>8)&0xff;
#endif
#if (NUM_TX_INT>0)
for(int i=0;i<NUM_TX_INT;i++)
txPacketBuffer[byte_pos++] = txPack.integers[i]&0xff;
txPacketBuffer[byte_pos++] = (txPack.integers[i]>>8)&0xff;
txPacketBuffer[byte_pos++] = (txPack.integers[i]>>16)&0xff;
txPacketBuffer[byte_pos++] = (txPack.integers[i]>>24)&0xff;
#endif
#if (NUM_TX_FLOAT>0)
float f;
byte *add;
for(int i=0;i<NUM_TX_FLOAT;i++)
f = txPack.floats[i];
add = (byte *)&f;
txPacketBuffer[byte_pos++] = add[0];
txPacketBuffer[byte_pos++] = add[1];
txPacketBuffer[byte_pos++] = add[2];
txPacketBuffer[byte_pos++] = add[3];
#endif
for(int i=1;i<TXPACK_SIZE-2;i++)
sum+=txPacketBuffer[i];
txPacketBuffer[byte_pos++] = sum&0xff;
txPacketBuffer[byte_pos] = 0x5a;
pSerial->write(txPacketBuffer,TXPACK_SIZE);
//Do not change the code above-----------------------
//// Communication protocol end//////////////////////
#define righA_PIN 9
#define righB_PIN 10
#include <Servo.h>
void motor_pinint();
void LEFTmotorcontrolGO();
void RIGHTmotorcontrolBACK();
void RIGHTmotorcontrolGO();
void LEFTmotorcontrolBACK();
void motorcontrolSTOP();
void LEFTmotorcontrolSTOP();
void RIGHTmotorcontrolSTOP();
void STOPP();
void sdcl();
/*电机引脚初始化*/
void motor_pinint()
pinMode (righA_PIN, OUTPUT); //设置引脚为输出引脚
pinMode (righB_PIN, OUTPUT); //设置引脚为输出引脚
pinMode (6, OUTPUT); //设置引脚为输出引脚
pinMode (5, OUTPUT); //设置引脚为输出引脚
pinMode (12, OUTPUT); //设置引脚为输出引脚
pinMode (2,OUTPUT);
pinMode (A0, INPUT);
Servo myservo;  // 定义Servo对象来控制
int pos = 0;    // 角度存储变量
int sudu=0;
int SPEED=0;
int led=0;
int closetime=0;
int opentime=0;
int dangwei=0;
int zhuanxiang=0;
int k=9900;
int i=0;
int sc=0;
int duoji=100;
int sd=0;
int zxcha=0;
unsigned long duration;
unsigned long A=0.0;//定义duration变量为无符号长整数型变量
void setup()
myservo.attach(11);
motor_pinint();
Serial.begin(19200); //串口波特率9600(PC端使用)
initPack(Serial,19200);
void loop()
if(recvPack())
sudu=rxPack.bytes[0];
duoji=rxPack.bytes[3];
zxcha=rxPack.bytes[4];
led=rxPack.bools[0]2;
*    sc=rxPack.bools[1];*
*    sd=rxPack.bools[2];*
*      if (sc==1) myservo.write(duoji);*
*      else myservo.write(100);*
*    dangwei=rxPack.bytes[1];*
*    zhuanxiang=rxPack.bytes[2];*
*    digitalWrite(12,led);*
*    SPEED=dangweisudu;
Serial.println(SPEED);
if(SPEED>9900){
digitalWrite(2,LOW);
RIGHTmotorcontrolGO();}
else if(SPEED<-9900){
LEFTmotorcontrolBACK();}
else if(SPEED>=1000)
opentime = map(SPEED, 1000, 9900, 200, 0);
closetime = map(SPEED, 1000, 9900, 5, 100);
delay(closetime);           //延时1000ms
if(zhuanxiang>=30)
k=(zhuanxiangSPEED)/100;
zhuanxiang=map(k,300,9900,zxcha,0);
delay(zhuanxiang);
motorcontrolSTOP();
delay(opentime);           //延时1s
else if(SPEED<=-1000)
SPEED=-SPEED;
if(zhuanxiang<=-30)
zhuanxiang=-zhuanxiang;
k=(zhuanxiang*SPEED)/100;
delay(zhuanxiang);
motorcontrolSTOP();
else{
motorcontrolSTOP();
STOPP();
if (sd==1) {sdcl();
sendPack();}
digitalWrite(righA_PIN, HIGH);
digitalWrite(righB_PIN, LOW);
digitalWrite(5, HIGH);
digitalWrite(6, LOW);
digitalWrite(righA_PIN, LOW);
digitalWrite(righB_PIN, HIGH);
digitalWrite(6, HIGH);
digitalWrite(5, LOW);
void STOPP()
delay(5);
digitalWrite(2,HIGH);
Serial.println("停止");
void sdcl()
duration = pulseIn(A0,HIGH);
A = 17278759.595/duration;
Serial.println(A);
txPack.shorts[0] =(A);
txPack.shorts[1] =(A/100*3.6);
//Serial.println(duration);
Search Datasheet?
Forum More
Update:2025-08-03 01:40:46
