蓝猫淘气
[Course Design] Quick power supply for 45MM wide breadboard
Introduction
Quick power supply for 45MM wide breadboard (SYB-130)
Power supply: 6-30V
Optional DC, MicroUSB input interface
Battery powered (any battery of suitable voltage)
Output:
Onboard output interface 5V, 3.3V, 1.25V
Breadboard interface, output jumper optional 5V/3.3V
Circuit details
DC and usb interface.
Use 7805 three-terminal voltage regulator to get 5V voltage, and LM317 to get 1.25V voltage
Onboard output power and indicator lights
The non-inverting input of the LM358 op amp is connected to 1.25v, the inverting input obtains output feedback through resistor voltage division, and then the output pin is adjusted to control the conduction degree of Q2 and Q3.
Revise
PS1: Added a few 100nf ceramic capacitors to increase the number of components to 30.
PS2: I was mistaken about the LM337 chip that outputs 1.25v, but it has been corrected to LM317.
PS3: Due to the voltage drop of the chip, the initially envisioned 5v and 4.2v power supplies could not reach the expected output voltage, so the unified power supply was changed to 6-30v.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 04:33:46
  • I love TI_M3 and M4
  • Design of DC brushless starting magneto and driving circuit for motorcycle
  • How to debug vxworks driver
  • There are so many colons in command.bib in wince
  • Can you tell me where the board you have comes from?
  • 2410+wince500 network card problem
