3228
LM5576 high power wide voltage DCDC, input up to 75V 3A
The LM5576-Q1 is an automotive grade product and qualified for AEC-Q1001 grade (operating junction temperature range -40°C to +125°C) and AEC-Q100 Grade 0 (operating junction temperature range -40°C to +125°C). +150°C) integrated 75V 170mΩ N-channel metal oxide semiconductor field effect crystal
Ultra-wide input voltage range: 6V to 75V
Adjustable output voltage as low as 1.225V
Can provide 3A continuous output current
The efficiency of the power amplifier is quite high, but it will also generate heat when working at high power, so certain heat dissipation measures need to be taken. Pay attention to component selection
The attachments include manuals and official evaluation board product pictures. It is recommended that the solder mask on the back be made larger.
There is actual test data in the attachment. It can be seen that the efficiency is quite good. The external load is 31Ω.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-03 21:34:44
