MartinFowler
PAM8403 power amplifier
Power amplifier circuit with PAM8403 as the main control
Use screw terminal blocks for easy wiring
Using the MicroUSB interface, you can supply power if you have a mobile phone charging cable at home
According to the working voltage of PAM8403, the power supply voltage should be between 2.8V ~ 5.5V, so I used USB power supply.
Each channel outputs 3W, and it can work when connected to 1W, 3W, or 5W speakers, but do not connect speakers with excessive power, otherwise the chip will be damaged!
ZH.png Front side of circuit board FA.png Back side of circuit board
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 04:33:47
