elleny
[Course Design] NE555 Delay Circuit (Monostable)
Introduction: This course is designed from the perspective of digital electronics experimental course design - NE555 timer and its application
The starting signal is a negative pulse input from pin 2. When no trigger signal is added, pin 3 outputs low power.
Voltage; after the negative pulse is triggered, pin 3 outputs high potential and automatically recovers after time t.
to low potential.
Principle: When the button is pressed,
o1QmIQxG2i2CS2B1uuHtSflsAVjI1sAEqwGdX5sf.pngCapacitor C3 discharges,
z4JboMjMRt9QPpveYVDCwJnKt3QzdJtHYR1TBGQB.pngAt the same time, pin 3 outputs high level. When C3 is discharged until the voltage of pin 7 reaches a certain level,
C3 starts charging, and pin 3 outputs low level . Pin 3 continues to output when the button is not pressed.
low level. The output high level time is related to the values ​​of C3, R4 and R5.
EKeWHpJC7Dk2hcJZwx4tQ220xeeDCnb63PTSIDa4.pngCalculation formula: t = 0.693(R4+R5)*C3
Physical map
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 00:33:35
