桂花蒸
E522.49-Automotive grade 16-channel LED constant current driver chip
E522.49, the microcontroller can control the current, duty cycle, switch and status reading of 16 LED output channels through the bus interface
  • Power supply voltage: 5V~40V
  • Built-in 16-channel PWM generator, 10-bit resolution
  • 16-channel programmable LED driver, maximum current per channel 100mA, output current step 100uA, adjustable rising slope
  • 2 priority PWMIN input interfaces, which can directly control the LED channel through the PWM signal on the PWMIN pin or the backup data in OTP
  • 10-bit ADC for LED open circuit, short circuit and system diagnostics
  • Support "single light" mode
  • Unique thermal management function: two-channel parallel output, reducing chip power consumption through external heat dissipation resistor
  • Configurable overvoltage derating output
  • Configurable over-temperature derating output
  • LED bin brightness correction
  • Optional external LED bin resistor evaluation
  • In the Failsafe state (for example, when the host (MCU) fails), the chip can continue to work based on the internally stored current and duty cycle data.
  • Operating temperature -40°C - 125°C (junction temperature 150°C)
  • AEC-Q100 automotive grade certification
  • Meets ASIL-B functional safety level
  • Package: QFN32L6
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 06:41:50
