uVawaYHK8
Monochrome eight light panel
Using 8 single-color LEDs in 335 package, evenly distributed to make the light even and soft.
It is recommended to purchase a resistor package and solder the resistor with the required resistance according to the brightness you need!
Gerber is included in the attachment and can be downloaded directly. You can directly make the PCB in Jiali Chuanghuang. If you want to make it yourself, you can just make 5 pieces for 5 yuan and just buy the lamp on Taobao and weld it.
It is recommended to use a heating table for soldering. If you are skilled in soldering iron, there will be no problem in soldering. The purchase links for lamp beads and heating tables are below. It’s just that I have no interest in the links I purchased.
Lamp bead link (find more colors in the store or contact customer service directly): https://item.taobao.com/item.htm?spm=a1z09.2.0.0.4fde2e8disYXvu&id=572513179090&_u=g201g3gispbc33 Resistor package link: https:/ /item.taobao.com/item.htm?spm=a1z09.2.0.0.4fde2e8disYXvu&id=551487508397&_u=g201g3gispa527 Heating table link: https://detail.tmall.com/item.htm?id=609967185418&spm=a1z09.2.0.0 .4 fde2e8disYXvu&_u=g201g3gisp61e8 solder paste link (very rarely used!): https://detail.tmall.com/item.htm?id=555299274372&spm=a1z09.2.0.0.4fde2e8disYXvu&_u=g201g3gispe2a8 You can go to Magnum b station to learn the specific welding operations!
There is no need for a keyboard PCB to reserve a light strip interface. You can draw power directly from the USB power supply or connect it to the light hole to draw power.
Support more keyboards without programming and lower cost!
The cost of a single piece is about 2 yuan!
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 19:25:34
