smallembedded
F411 flight control
Sensor: MPU6000+BMP280+QMC5883 Interface: PWM×6, uart×2, LED, buzzer, OSD, USB
Size: 30×30mm, mounting hole 20×20mm
Schematic 1
SensorPCB positivePCB reverse
Description:
1. The resistance detected by VBAT is 10K: 1K, There is no change in the schematic diagram, just solder 10 directly on the PCB.
2. After the test flight, the self-stabilization is very strong and the heading is very stable.
3. The BF firmware used is 3.5.7. After upgrading to a higher version, the magnetometer will not be able to detect it. (The manufacturer seems to have stopped producing the flight controller. It is probably because the subsequent firmware will not be maintained.)
4. There seems to be something wrong with the OSD. You can update the font. The OSD display in the Task list is also normal, but the image transmission cannot receive the picture. (I’ll work on it later, I’ll update it when it’s done...)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 17:16:36
  • Ultrasonic alarm data download
  • WinCE 5.0 2440 crashes when waking up
  • Lithium battery charging problem
  • Sleeping taboo
  • Detailed Explanation of Embedded Linux Application Development
  • Regarding the problem of variables in pic, the value of the variable suddenly changed
