newrudeman
ESP communication burning module
Only one different version of the same project can be displayed at the same time. Switch to different versions if necessary.
Version 4.0: Communication download and programming module, using 2 LDO power chips to separately power the ESP module and CH340C, supports TYPE-C and Micro USB interfaces, supports ESP-01, ESP-12, ESP-32 module communication download, ESP-12, ESP-32 module connection part uses test jumper soldered spring bayonet for easy disassembly.
Version 2.0   :
Download and burn the communication module. I used 3 LDO power chips to enhance the power supply. It supports TYPE-C and Micro USB interfaces. The external pin header can be downloaded to other devices. You can also use the resulting action level to download the STM32 program on the Arduino IDE. It is incorrect and cannot be downloaded automatically. You can only manually jump to BOOT0 to download.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 04:00:52
