qoistoochee128
[To be tested] IP53062.1A charging 3A discharge mini power bank
[Project code: LB226_5306S] 1 Features   Synchronous switching charge and discharge  3.1A synchronous boost conversion, 2A synchronous switching charging  Boost efficiency up to 93%  Charging efficiency up to 92%  Built-in power path management, supports charging and discharging at the same time  Charging  Automatically adjust the charging current to match the adapter output capability  Supports 4.20V, 4.30V, 4.35V and 4.4V batteries   Power display  Supports 4/3/2/1 LED power display   Rich functions  Button power on  Built-in lighting Lamp driver  Automatically detects the insertion and removal of mobile phones  Supports load high current line compensation function   Low power consumption  Intelligently identifies the load, automatically enters standby   BOM** minimalist  Built-in power MOS, single inductor realizes charging and discharging   Multiple protections, High reliability Output over-current, over-voltage, short-circuit protection Input over-voltage, over-charge, over-discharge, over-current discharge protection In-  depth customization I2C interface, flexible and low-cost customized solutions2 Applications Mobile  power supply / power bankPortable devices such as mobile  phones and tablets 3 **Introduction IP5307** is a multi-functional power management SOC that integrates a boost converter, lithium battery charging management , and battery power indication, providing a complete power solution for mobile power supplies. IP5307 **'s high integration and rich functions require only a few peripheral components for application, effectively reducing the size of the overall solution and reducing the BOM cost. IP5307** only needs one inductor to implement buck and boost functions, and can support low-cost inductors and capacitors. The synchronous boost system of IP5307 provides a full 3.1A ** output current and a conversion efficiency as high as ** 90% ( 5V@3.1A **). When no-load, it automatically enters sleep state. IP5307** adopts switching charging technology, providing up to 2A current and charging efficiency as high as 90% (5V@2A) . Built-in IC temperature detection and input voltage detection intelligently adjust charging current. IP5307 supports 1/2/3/4 LED ** power display and lighting functions, ** IP5307 supports I2C ** interface to read chip information (customized model ** IP5307_I2C **). IP5307 is packaged in ESOP8. All in all, it is a cost-effective IC among low-end configuration ICs.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 16:53:02
