王达业
Arduino modular multi-way solenoid valve controller
some words
  • Imported from KICAD, unorganized, use with caution. If you need to pattern making, please use the pattern making file I provided.
  • It is mainly used to control the cylinder operation on some ultra-small automation projects. People who engage in automation should be familiar with it.
  • You may ask why you don’t use PLC. First, PLC is expensive and you are too lazy to learn it.
  • Then some people asked why not use the ready-made time controller and relay combination? It is also expensive, takes up space, and is inconvenient for wiring, setting parameters, maintenance, and stability.
  • Developing with Arduino is very fun. It is more than enough to use a timer to control several cylinders to run independently. You can even add an OLED menu.
  • The hardware generally adopts a modular design, which facilitates quick maintenance. I have also made several sets of boards for industrial control. They have been used for nearly a year. They are currently very stable and no abnormalities have been found. Only sometimes the DCDC modules are burned due to inferior DCDC modules being sold.
  • There is also a 1-way stepper motor version, please consider releasing it if you are interested.
  • Usage video display
  • Some reference videos on cylinder control principles
  • Can control up to 4 cylinders, connect up to 8 sensors and 2 buttons
  • Provides a sample program for controlling 4 cylinders. Only 2 cylinders are activated and detected by sensors, with error alarm prompts.
hardware
  • To use the arduino nano module, you need to flash BL to uno in advance.
  • Main control, MOS driver, DCDC, and OLED use modular design
  • The sensor input port uses diode isolation and only supports NPN/LOW input.
  • Rotary encoder input and button input use resistance-capacitance filtering to enhance anti-interference
  • 24VDC power input, reserved terminal block for controlling the power switch
  • tvs anti-surge of DCDC module
  • Spring-type screw-free terminal blocks save time and effort
  • The DCDC step-down module can be adjusted to 6.5V for use. It will step down twice through the LDO of the nano module and be used by peripheral 5V modules.
software
  • Chinese menu interface
  • OLED main interface monitors input and output status, manual/automatic switching operation
  • Setting menu, cylinder running time setting, screen rest time setting, screen brightness, sensor on/off, reset
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 16:52:15
