张三叔
24-bit differential ADC module-CS1237
Module introduction
This module uses CS1237 as a conversion chip to convert tiny voltage signals into digital signals with 24-bit precision.
The signal input end of the module can accept differential signals, and there is a programmable operational amplifier inside to amplify the weak signals at the input end.
The module has a built-in temperature sensor that can roughly estimate the surrounding temperature.
Modules can be used in a variety of industrial process control situations, such as electronic scales, blood meters, smart converters, etc.
Pin function table
symbol
CLK OUT VCC GND E+,E- S+,S-
describe Communication interface, clock input terminal Communication interface, data output terminal Power voltage input, 3V-5.5V power ground Excitation voltage output terminal Small signal input terminal
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 12:48:04
