toothache
# Sixth Lichuang Electric Competition #Bluetooth Speaker Amplifier
Note: * is required
Please fill it out during the registration stage↓
* 1. Introduction to project functions
1. DIY project, a hardware novice, the goal is to make a single-channel Bluetooth speaker that can play songs while working overtime.
2.18650 charge and discharge, self-designed 3D shell, Bluetooth module purchased from Taobao
3. The power amplifier uses 1875, and the SPK uses Hivi 10W (20Wmax)*1
4. Powered by 5V type-c
5. The charging circuit has been solved (Lichuang board verification completed)
6. The first version of the power amplifier circuit has failed, and the second version is currently undergoing design verification.
7. The 18650 needs to be boosted to above 16V to drive the power amplifier. At present, this part of the circuit is still in a novice state (a suitable boost chip has not been found yet)
8. The first generation of DIY speakers is only for Bluetooth playback and charging, and subsequent iterations will consider adding special effects such as touch controls and level lights.
*2. Project attributes
Original and public.
Note: Please indicate whether the project has been made public for the first time; whether the project is original; whether the project has won awards in other competitions; if so, describe the details of the award; whether the project has participated in a defense in school.
* 3. Open source agreement
I don’t know much about open source protocols, so I use GPL3.0 as recommended.
Note: Altruism means self-interest, please read the following content carefully.
  1. Embrace open source and give projects unlimited value. It is recommended that more than 80% of the core functions of the project be open source;
  2. If a certain part of the function is irreplaceable and the project cannot solve the corresponding problem after deletion, then the function implemented by this part is the core function of the project; for example, if an electronic load is designed and a host computer software is designed to monitor power changes, the electronic The load is the core function, and the host computer software is the auxiliary function; for example, an isolated 485 module is used in the electronic load to communicate with the host computer, then the communication function implemented by this 485 module is an auxiliary function;
  3. Projects should choose an open source agreement that suits them . If the project references other open source projects, the source should be indicated and follow the original author's open source agreement. It is recommended that original projects use the GPL3.0 open source agreement;
  4. Functions implemented by directly quoting the original circuits or original codes of open source projects cannot be used as the core functions of one's own projects, and functions directly implemented using common modules on the market cannot be used as core functions of one's own projects.
Please fill in during the competition stage↓
*4. Hardware part
Please enter content...
Note: It is recommended to use Lichuang EDA . If you choose other EDA tools, please upload schematics in PDF format, PCB drawings in PDF format, and PCB files in Gerber format in the attachments. Here you can explain in detail your project implementation principles and mechanisms, precautions, debugging methods, testing methods, etc. It is recommended to introduce your ideas to others in the form of pictures and texts.
*5. Software part
Note: If your project involves software development, please upload the corresponding project source code in the attachment. Here you can describe in detail your software flow chart, functional module block diagram, explanation or popular science of related algorithms, source code structure, construction and configuration of compilation environment, source code compilation method, program burning method, etc. It is recommended to introduce your ideas to others in the form of pictures and texts.
*6. BOM list
Note: BOM list involved in the project. Please upload a screenshot of the BOM at this location. Please upload the list details in PDF format to the attachment. Suggestions include model, brand, name, packaging, procurement channels, usage, etc. The specific content and form should be based on clearly expressing the project composition.
*7. Contest LOGO verification
Please upload a project picture containing the competition logo. The logo will be printed on the PCB in the form of silk screen printing.
Click the zip to download the competition logo! (Contest logo).zip
* 8. Demonstrate your project and record it as a video for uploading
Video requirements: Please shoot horizontally, with a resolution of no less than 1280×720, in Mp4/Mov format, and the size of a single video is limited to 100M;
Video title: Lichuang Electric Competition: {Project Name}-{Video Module Name}; such as Lichuang Electric Competition: "Autonomous Driving" - Team Introduction.
More details: https://diy.szlcsc.com/posts/06c94d90c2c447dfbd9ed7339ff4a5b1
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 20:36:02
