alYLo3
Aili style 34 - 3 to 6 string lithium battery charging can limit the current and support lithium iron phosphate
MP2659
The input voltage is 20-36V ( please note that the input voltage must be higher than the full charge voltage of the battery pack )
Supported battery pack types:
3.6V lithium iron phosphate
4.15V/4.2/4.35 lithium battery
Output current, maximum 3A
Onboard current is adjustable, 1A/2A/3A/potentiometer adjustment
The onboard battery type is adjustable, and the above four battery packs can be adjusted and switched
Onboard charging string number switching
Reserved NTC resistor on board, you can weld 103AT or disable NTC
2 LED lights indicate charging status
The figure below shows the output voltage accuracy. It is recommended that the target battery pack has complete protection functions.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 12:49:02
