qoistoochee128
USB voltage and ammeter
Introduction
A USB voltage and current meter based on STM32 can easily see whether the charger is working in fast charging mode, and can also easily test the power consumption of USB devices or the output power of USB chargers.
Version update instructions
v1.1 - 2020/4/15
  • An automatic screen-off function is added. After detecting no current output for 20 seconds, the screen will automatically turn off to protect the OLED screen. After the screen is paused, the screen will automatically light up when current output is detected or a button is pressed manually.
characteristic
  • Based on STM32F030K6, the code is written using HAL library and GCC compiler
  • 0.91-inch white OLED display with clear display effect
  • Use low resistance sampling resistor (5mΩ) to prevent excessive internal resistance from affecting USB power supply efficiency
  • Supports a wide voltage range of 4.7~24V and current measurement of 0~5A
  • Can measure Vbus, D+, D- voltage, Vbus current. Support power display and energy calculation
  • Optional use of internal voltage reference source (Vref) or external voltage reference source (AZ431)
  • Software calibration function can ensure a certain accuracy after calibration.
  • Completely open source, you can add functions by yourself
Calibration instructions
This USB voltage and ammeter is designed with a software calibration function that can compensate for hardware deviations. When powering on, press and hold the button until "Prepare to calibrate~~~~" appears on the screen, then release the button to enter the calibration mode. Please follow the screen prompts to provide standard voltage and current to complete the calibration.
Code description
The code is a trueStudio project generated through STM32CubeMX. It is recommended to use trueStudio 9.3.0 to import and use.
Precautions
There are two types of USB female sockets, one with the internal contacts facing down (facing the pad) and the other with the internal contacts facing up (back to the pad). These two female sockets can use the same PCB package. If you have used a USB female socket with lower contacts, the female socket should be welded to the front of the board, otherwise it should be welded to the back of the board. The example picture uses a USB female socket with lower contacts, and the female socket with upper contacts is designed in the schematic diagram and PCB. Please pay attention to this when making.
Recommended mother seat:
  • Upper contact (soldered back): C265460
  • Lower contact (soldered front): C464564  (used in example picture)
Physical picture
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 06:42:15
  • Firmware library 3.5.0
  • Problems with downloading wince program to development board?
  • Easy Power Source Learning Share your scores and experience.
  • There was no news about this year's e-sports competition.
  • Poems about Tea
  • STarm Selection Guide
