newrudeman
esp8266/esp32 multi-module/typec port burner
ESP32/8266/ESP01S programmer, all modules have been programmed without any problem (and they are all programmed automatically). Tuya XR3/WB3S debugging board. When debugging, connect the external circuit through the pin header. To debug the Tuya DP point, you can connect the board Use the external programming port for debugging. Each module power inlet is passed through filter capacitors. This board is based on the open source platform's programmer. Those who want to make can also go and see their projects.
Added typec interface!
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 08:11:04
