他们逼我做卧底
Multi-Signal Generator (2019)
Multi-signal generator (2019), the project contains some sub-circuits and the overall circuit, the output is 1. A continuously adjustable square wave pulse signal with a frequency of 1%kHz~2kHz, the amplitude is not less than 3.2V 2. The same frequency as the square wave Sine wave signal, the output voltage distortion is not greater than 5%, and the peak-to-peak value (vpp) is not less than 1V. 3. A narrow pulse signal with a continuously adjustable duty cycle of 5%~15% at the same frequency as the square wave, and the amplitude is not less than 3.2V. 4. The phase error of the cosine wave signal that is orthogonal to the sine wave is not greater than 5°. The output voltage peak-to-peak value (Vpp) is not less than 1V. Each signal output must be connected to an IkΩ load resistor. The engineering is defective and will be continuously modified and improved.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 18:04:34
