aytwartoofyoroo
[Verified]ina219 current and voltage detection module-with code
Chip characteristics
Sensed bus voltage range: 0V to 26V
Reports current, voltage, and power
16 programmable addresses
High accuracy: ±0.5% accuracy over entire temperature range
Filtering options
calibration register
Tutorial
Use Dupont wires to connect the positive and negative and i2c interfaces to arduino, then download the attached arduino ina219 library and put it in the libraries folder
#include
#include
Adafruit_INA219 ina219;
void setup(void)
  Serial.begin(115200);
  while (!Serial) {
      delay(1);
  uint32_t currentFrequency;
  Serial.println("Hello!");
  // 初始化会默认使用最大测量范围(32V, 2A),你也可以使用setCalibration指令更改,以获取更高的精度
  ina219.begin();
  // 用 32V, 1A 范围来测量会获取更高的电流测量精度,如果想使用这个选项就删除下面那行的注释
  //ina219.setCalibration_32V_1A();
  // 用16V, 400mA 范围来测量会获取更高的电流和电压测量精度,如果想使用这个选项就删除下面那行的注释
  //ina219.setCalibration_16V_400mA();
  Serial.println("Measuring voltage and current with INA219 ..."); //打印‘正在使用ina219测量电压和电流’
void loop(void)
  float shuntvoltage = 0;
  float busvoltage = 0;
  float current_mA = 0;
  float loadvoltage = 0;
  float power_mW = 0;
  shuntvoltage = ina219.getShuntVoltage_mV();
  busvoltage = ina219.getBusVoltage_V();
  current_mA = ina219.getCurrent_mA();
  power_mW = ina219.getPower_mW();
  loadvoltage = busvoltage + (shuntvoltage / 1000);
  Serial.print("Bus Voltage:   "); Serial.print(busvoltage); Serial.println(" V");    //打印总线电压
  Serial.print("Shunt Voltage: "); Serial.print(shuntvoltage); Serial.println(" mV"); //打印分流电压
  Serial.print("Load Voltage:  "); Serial.print(loadvoltage); Serial.println(" V");   //打印负载电压
  Serial.print("Current:       "); Serial.print(current_mA); Serial.println(" mA");   //打印电流
  Serial.print("Power:         "); Serial.print(power_mW); Serial.println(" mW");     //打印功率
  Serial.println("");
  delay(2000);
Achievements
The load is connected to an Arduino UNO board without other loads. The accuracy has not been tested. Next time, I will compare it with a Lichuang multimeter.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 08:17:33
