兰博
[Changshu University of Technology] 51 microcontroller lighting design
Competition requirements
(1) Use Easy EDA to design a running water lamp (5~7 lights) with touch function;
(2) Touch switch is used to switch the effect of the running water lamp: constant light mode, running water lamp mode, delay Lights-off mode (3) The touch function can be implemented through the touch module; it can also be implemented using photoresistors, grayscale sensors, etc. If touch control is not possible, use buttons instead of this function.
(4) Improve requirements: Different lighting indication effects can be produced through external light, sound, temperature and other parameters.
(5) Other explanations for other functions: This question recommends the use of controller design. The controller must be prepared by itself. The necessary interfaces are provided for the controller in the circuit design and connected during physical debugging.
Awards
third prize
Team members: Shen Yue, Sun Ling
Instructor: Xu Jian
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-06 18:45:42
