3228
HNA-16MM64 professional power amplifier VFD display module
EEI TECHNOLOGY HNA-16MM64 VFD power amplifier display module
  • Features a wide voltage input range of 5-24V.
  • Onboard level conversion chip, adaptive to 3.3V/5V level (compatible with 51, STM32 and other mainstream microcontrollers).
  • The improved Cuk negative pressure and filament driving scheme has lower power consumption and more uniform brightness.
  • Use professional VFD dot matrix driver chip, built-in font library, and 8 custom symbol spaces.
  • 8 levels of brightness adjustable.
  • The maximum power consumption is about 2.65W (full brightness, 15/16 pulse width, 5V input).
  • Built-in dynamic scanning logic and RAM, you only need to send instructions to the driver chip to complete the display.
  • You can buy the screen from the manufacturer (Shanghai Pufeng Optoelectronics) at a cheap price.
Notice
  • PT6302LQ is not resistant to high temperatures. Do not use a hot air gun to solder directly from the front! !
  • The big and small endian of the initialization command of PT6302 and the font command are opposite, so you must pay attention when using them.
  • This project is for DIY and learning purposes only. Any sale, dissemination, or copying of this open source project for commercial purposes is prohibited (including modifying its frame and silk-screening it for sale).
  • Investigate all piracy and counterfeiting (recently, it was discovered that a second-hand dealer deleted the "EEI TECHNOLOG" LOGO on an e-commerce platform and copied the board number and version number format of EEI TECHNOLOGY for sale, which has had a bad impact on my studio). For this kind of behavior , we will crack down severely when necessary!
Show results
  • back of board
  • Light up renderings
  • Added wine red filter
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 06:23:00
