张三叔
BH1750 light sensor
BH1750 sensor module
Module parameters
  • I2C digital interface, supporting speed up to 400Kbps
  • The output quantity is illuminance (Illuminance)
  • Measuring range 1~65535 lux, resolution as small as 1 lux
  • Low power consumption (Power down) function
  • Shields interference from light changes caused by 50/60Hz mains frequency
  • Supports two I2C addresses, selected via ADDR pin
  • Small measurement error (maximum accuracy error +/-20%)
Module pin description
pin
illustrate
VCC Supply voltage source positive
GND Supply voltage source negative pole
SDA IIC data line, bidirectional IO port, used to transmit data
SCL IIC clock line, clock input pin, clock output by MCU
ADDR IIC address line, when connected to GND, the device address is 0100011, when connected to VCC, the device address is 1011100
Detailed tutorial: Super detailed guide to BH1750 light sensor (from principle to code explanation, you will understand after reading it)
appendix:
BH1750 library file
BH1750 test code
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 05:18:59
