newlandmark
32U4 keyboard-Kawvin_KB1002_V1.2
100 keys + 2 knob keyboard, features:
1. There are 4 splitting schemes for the space bar:
The space bar can have four splitting schemes :
100 keys: 1.25U+1.75U+1.75U+1.5U
  99 keys: 3U+1.75U+1.5U
  98 keys: 3U+3U
  97 keys: 6.25 U
2. The 2 knobs can be changed into two ordinary knobs, non-hot-swappable (if you want to use hot-swapping, please change the copper eyelets)
3. Other keys are hot-swappable
4. LED3528 reverse sticker light
5. zuoer68 revised shell scheme, (Refer to the installation tutorial: https://www.bilibili.com/video/BV15L411V7bh?p=1)
5.1 The modified plan does not use cotton strips to fix the PCB;
5.2 The original plan uses cotton strips to fix the PCB.
The above plan and 3D construction Please see the attachment for the mold renderings;
6. Support VIA key change operation;
7. Two lighting firmware versions
7.1 Rev100 linear lighting solution (supports VIA and keyboard to set lighting effects)
7.2 Rev200 matrix lighting solution (VIA setting of lighting is not supported, only lighting effects can be set on the keyboard)
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-01 16:48:21
