toothache
USB power meter with QC3.0 adjustable output voltage
V2.0 (corresponding to Sheet_2 and PCB2)
  • The main control chip is replaced from STM32F030 to ESP8266.
  • Added the function of viewing data and adjusting the output voltage through wireless connection (when connected to a QC2.0/3.0 charger), and removed the function of manually rotating the potentiometer to adjust the output voltage.
  • Small size and portable (4.6cm*3cm) design.
V1.0 (corresponding to Sheet_1 and PCB1)
  • When connected to the QC3.0 charging head, it can be used as a power supply with an adjustable output voltage in steps of 200mV.
  • When connected to QC2.0, several fixed voltages can be output.
  • Can be used as a USB power meter to measure voltage, current and power.
  • The onboard 0.96-inch OLED screen displays parameters such as output voltage, current and power.
  • On-board temperature sensor can issue a prompt when the circuit board temperature is too high.
  • Onboard EEPROM can store and play back data.
  • The onboard rotary potentiometer adjusts the output voltage (when QC2.0/3.0 charger is connected).
  • Small size and portable (5cm*3cm) design.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-29 14:08:16
