PWM DC motor speed regulator 5V-16V12V speed control switch 10A switch function LED dimming speed control module
1. Maximum voltage limit: 16V Minimum voltage limit: 5V Continuous current: 10A
2. Short circuit maximum current limit: 2OA (less than 10 seconds)
3. Speed control mode: PWM stepless speed regulation, which can also be used to adjust the light control method: speed control potentiometer (open clockwise, continue from
4.1% to 99% speed clockwise)
5. Duty cycle: 0%-99% (the 0% position is the leftmost closed state of the potentiometer) when the current is turned on, 0.002A (there will be no current in the speed regulator if it does not need to be turned off for a long time).
6. Efficiency: The efficiency is as high as 98%.
7. Volume: 30mm long (excluding potentiometer), 21mm wide, 14mm high
Update 2022/8/3: Add the most powerful interactive HTML BOM on the surface
