Lemontree
Cube-101_esp-tool burning and debugging tool
ESP chip universal programming debugger
Save the scarce USB to serial port chip, the current price of CH340k is outrageous
·CH340C classic solution, up to 2M baud rate
·USB to UART (Type-c form factor)
·Pin definition:
  • Control line-->SBU1/SBU2
  • UART communication --> CC1/CC2
·Note: The interface is compatible with AC cables and USB communications. Some weird full-featured cc cables are not necessarily compatible. I can’t afford to use them anyway.
The Type-C male connector will become unstable after welding, so it is best to seal it with glue.
ps: Early projects do not meet the specifications, so just make do with it.
Project introduction & preview:
The Dark-Cube project is
Naming standards:
Cube-001_Universal base plate-standard version
| | ---->Detailed name
| ----> Project serial number
-----> Series name
Project serial number:
  • 0xx: First generation standardized development board (obsolete)
  • 1xx: second generation standardized development board
  • 2xx: Power module (merged into other series)
  • 3xx: Smart Home (merged into other series)
  • 4xx: Side projects
  • 5xx: Function module
Hardware version specification
  • The hardware version control method of the "Cube" series is based on the Semantic Versioning Specification 2.0.0 , with appropriate modifications.
  • Long format yyyy.mm.dd ver0.0
  • Short format yymmdd v0.0
  • Among them, the date is the date when the version was last modified
  • Only the major version number and minor version number are retained, and the rest are implemented in accordance with Semantic Versioning Specification 2.0.0
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 23:22:42
  • The OnCreat function in the EVC dialog box is not executed?
  • STM8 clock problem
  • About the role of return
  • Today is different
  • Low Power RF Low Noise Amplifier
  • Real-World EMI Control
