Lemontree
LMT70--temperature sensor
The LMT70 is an ultra-small, high-precision, low-power complementary metal-oxide semiconductor (CMOS) analog temperature sensor with an output enable pin. The LMT70 is suitable for nearly all high-precision, low-power, cost-effective temperature sensing applications, such as Internet of Things (IoT) sensor nodes, medical thermometers, high-precision instrumentation and battery-operated equipment. The LMT70 is also an ideal replacement for RTDs and high-precision NTC/PTC thermistors.
Multiple LMT70s can use the output enable pin to share an analog-to-digital converter (ADC) channel, simplifying the ADC calibration process and reducing the overall cost of precision temperature sensing systems. The LMT70 also features a linear low-impedance output that enables seamless interfacing with off-the-shelf microcontrollers (MCUs)/ADCs. The LMT70's heat dissipation is less than 36µW, and this ultra-low self-heating allows it to maintain high accuracy over a wide temperature range.
LMT70A has excellent temperature matching performance. The temperature of two adjacent LMT70A taken out from the same tape and reel can differ by up to 0.1°C. Therefore, the LMT70A is an ideal solution for energy metering applications where heat transfer needs to be calculated.
  • Accuracy:
    • ±0.05°C (typ) or ±0.13°C (max) from 20°C to 42°C
    • ±0.2°C (max) from -20°C to 90°C
    • ±0.23°C (maximum) from 90°C to 110°C
    • ±0.36°C (max) from -55°C to 150°C
  • Wide temperature range: −55°C to 150°C
  • Temperature matching of two adjacent LMT70A in tape and reel packaging: 0.1°C (maximum) at 30°C
  • Ultra-linear analog temperature sensor with output enable pin
  • Negative Temperature Coefficient (NTC) Output Slope: -5.19mV/°C
  •  Output on/off switch when R DS on < 80Ω
  • Wide power range: 2.0V to 5.5V
  • Low supply current: 9.2µA (typ) 12µA (maximum)
  • Ultra-small 0.88mm x 0.88mm 4-bump WLCSP (DSBGA) package
application
  • Internet of Things (IoT) sensor nodes
  • Industrial Resistive Temperature Detector (RTD) (Class AA) or Precision NTC/Positive Temperature Coefficient (PTC) Thermistor Replacement
  • Medical/Fitness Equipment
  • medical thermometer
  • human body temperature monitor
  • Metering temperature compensationLMT70-ZHCSDV8Athe image is only a reference. Other pin/package combinations may be available.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 05:34:10
  • The OnCreat function in the EVC dialog box is not executed?
  • STM8 clock problem
  • About the role of return
  • Today is different
  • Low Power RF Low Noise Amplifier
  • Real-World EMI Control
