桂花蒸
Repair and replacement cable for Toshiba U920t
The original machine cable arrangement was changed to two 0.6mm small boards, with a 250mm long 0.5mm spacing FPC soft board sandwiched between them. One soft board costs about 0.35 yuan. From the original 40pin dual-row 0.4mm interface to the 40pin 0.5mm FPC interface of H1.0, it is connected to another board in the screen part through an FPC cable. It is also connected to the FPC interface of H1.0, and then transferred to the 40pin EDP interface. seat. After testing, the opening and closing is normal, but the installation is troublesome. The FPC cable is easy to break. It is not recommended to open and close frequently. Fortunately, the cable is cheap and you can buy many for 10 yuan.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-26 01:42:34
  • A newbie needs help with a question.
  • Beginner's Guide to PIC Microcontrollers
  • gogogo
  • Use GD32 to make a music spectrum to practice
  • Job seeking: Does anyone need a senior WINCE engineer? Only in Shenzhen area!
  • Experience in making photosensitive circuit boards
