太白金星
cx341 ocp to pcie
This adapter card is modified from this brother's project: Qieyou
Because there was a slight problem with the original hole position, I made slight adjustments to the hole position. The cx341a comes with a 5v step-down module, so I connected the 12v to the 5v pin.
There is also a 5v separate power supply version, buy a single-hole stamp DC-DC power module
This BTB connector must be soldered with a hot pot (the handicapped person recommends directly creating stm to save worry). Soldering with a hot air gun or a soldering iron will cause tin to be connected internally. The thing is very simple and there is nothing to say. The SH connector of the cooling fan You may have to crimp the terminals yourself, crimping plier model SN-03BM
The cooling fan I bought is 3cm x 7.5mm from Qisu. The screws must be M3*10 with small countersunk heads. The copper pillars must be double-pass M3*12 and the screws must be M3*4.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 02:52:25
